This one here is what I put in my SS and my Z06, all pretty much the same price.
Why wrestle with your hydraulic system every time you want to bleed it? Rely on Tick Performance to make the job much easier for you with our "One Man Job" Remote Clutch SPEEDbleeder Line. Fits 97-04 Corvette & Z06, 04-06 GTO & 98-02 Camaro & Firebird LS1
www.tickperformance.com
See what the LS7 Clutch Kit is from them too.
You see where it goes in the GTO, which is pretty much the same as the Fbody given the same transmission setup. I put one in my Z06 when I did a Master Cyl replacement from killing it at Tail of the Dragon, that is where that $50 part is next level worth it.
To bleed the Clutch in the C5-C7 Corvette you need to remove the Exhaust and Floor Pan Mid Brace just to even get to the bleeder bolt you see there off to the right..
The reason why it's spaced apart like that is because I took that Speed Bleeder and installed it in the car without removing the Slave Cyl. The planets had to align for this to happen. It got done tho, only had to make one custom tool, deep well 1/4" socket cut out to clear the line while I could tighten the line on the AN Fitting that it goes on, there is an adapter you install first on the Slave Cyl with the copper washer.
Pics here of the fun that was involved..
Stock bleeder bolt removed and adapter in
Bleeder line tightened on the adapter
Bleeder line ran along the stock line to the Slace Cyl and heat wrapped. I have it secured to the Hood Latch on that side if I need it
I probably posted pics at the time I did this, talking about again doesn't hurt given in this car that $50 part is worth it's weight in gold. Sooo much time saved with having that installed.
Supercharged111 some info here if you have to do it, it can be installed in the car without removing the Torque Tube, just takes one custom tool and a few choice words..
