1979 cutlass build
IMG_1199.JPG IMG_1200.JPG A friend of mine had his guys blast the frame for me and prime it so it wouldn'tIMG_1209.JPG IMG_1203.JPG rust
some more pics found the vin number on one side and some other number on the other side,IMG_1201.JPG IMG_1202.JPG IMG_1204.JPG IMG_1205.JPG IMG_1206.JPG IMG_1208.JPG IMG_1210.JPG only one small hole and 4 body mount holes to fix not bad for 36 years old and a Michigan car
IMG_1251.JPG IMG_1252.JPG IMG_1253.JPG IMG_1254.JPG IMG_1255.JPG IMG_1256.JPG IMG_1257.JPG IMG_1258.JPG I bought a harbor freight sandblaster works ok using it in a blast cabinet I built.I blasted and primed and painted some parts so they wouldn't rust
Nice work. Sandblasting parts does wonders. I remember the first time I used one and then looked back at all the lost time scrubbing with a wire brush.
:doh:
I installed all my ball joints and bushings today and experimented with some evaporust but with out much success, so i'm leaving the stuff soaking over night I also made some patterns for my boxing plates
Be sure to give us an honest review of Evaporust. I'm curious to hear if it's as good as they claim it is.
well my results are inconclusive at this point some bolts the heads look great some it looks like nothing happened the shifter bracket looks great but has a yellow haze??? the one fuel line clip looks great,now it was cold last night and it does say to use at 65* or higher so I moved the operation inside and im going to experiment with some wire brushes and what not and warmer temp, im still soaking my blazer spindle to see results of that I will update when I have more info, if anyone sees this that has advise for using this stuff please chime in
ok so I just got back from grocery shopping and there is a home depot near by so I stopped in and went to the paint department to check out metal rescue, similar to evaporust , while looking I found something called phosphoric acid says cleans rust and leaves a protective coating it was 15 bucks so I got a gallon so I will try this in a separate container and report back to see if its any better
the evaporust does work but not on heavely rusted stuff it did work on nuts and bolts but they still require a wire wheeling before priming so I think you could skip the evaporust and just wheel them I not fully convinced the stuff is the end all miracle
  • Informative
Reactions: DRIVEN
