1979 cutlass build
88hurstolds
1,748
658
I used Evap-o-rust on lightly rusted parts, worked nicely however I left my stuff in for 24 hours.
One mystery is that it turned a shifter gear selector arm completely black, I am assuming it was because it's galvanized??? It was caked in grease/crap so I threw it in with a few other brackets thinking that there was rust under the grease caking and to see how well it removed that as well.
1bad79
1,023
890
Allendale mi
I saw a evaporust you tube video and it said the black was carbon from the steel and it should just wipe away? I had to wire wheel it off. I think I want to try it in a sonic cleaner and see what it does for fun and I will try some stuff for a longer period of time also
1bad79
1,023
890
Allendale mi
i cut some boxing plates and tacked them in than welded them up,i made them out of some .125 plate I had laying around I just used a jig saw and a metal blade to cut them out, it worked well
I still have more plates to make to tie it all together
1bad79
1,023
890
Allendale mi
IMG_1320.JPG IMG_1310.JPG IMG_1311.JPG IMG_1312.JPG IMG_1313.JPG IMG_1314.JPG IMG_1315.JPG IMG_1316.JPG IMG_1317.JPG IMG_1318.JPG I also repaired some body mounts there were 4 bad ones I used 1.5 inch washers drilled a hole for the slot cleaned the slot with a bur and cut then up so they would fit and welded them in and ground them smooth
1bad79
1,023
890
Allendale mi
IMG_1205.JPG IMG_1321.JPG IMG_1322.JPG IMG_1323.JPG some more pics left rear behind the tire and right front corner
truracer20
492
31
western PA
I'm liking the progress. I'm wanting to find a frame to do this to for my car. So it's nice to see what others are doing, how they overcome the issues encountered.
I have seen Evaporust used on surface rust and it works great. I've been wondering how it works on scale rust like the parts on these cars end up with. Now I know at least how it worked for you.
1bad79
1,023
890
Allendale mi
if any one sees this, can you tell me what the purpose of the small slots in the body mount holes are for,a friend of mine asked me and I have no answer for them
Rktpwrd
Builder of Cool Shjt
4,179
23,973
Calgary, Alberta, Canada
Wish I knew. I can only speculate that GM originally designed it that way to work with a different style of body mount. When I boxed and repaired some questionable holes in my frame, I didn't put the slots back in, I didn't see the point.
1bad79
1,023
890
Allendale mi
I thought about not putting them in also but I chickened out and made them look the same
