1980 Malibu Wagon resurrection
Good to see you making headway. Once the engine's in and running it will inspire you to continue on your quest to make it driveable once again.
Keep up the good work. 👍
Did a little bit this weekend but nothing too exciting... got the cluster re-installed. Installed battery tray and battery, set radiator in and overflow. There’s some cracks in the fan shroud so got stuck on that. Is there a good aftermarket solution for this that’s not too much $$$.
Reactions: fleming442
Hmmm Interesting, at least I'll know what the inside of the Cluster looks like, but I am also noticing like my 81' Malibu Coupe that you do not have a Needle pointing to what gear it is shifted to on the column, I am wondering if that was common in these cars?
After almost 40 years, they're super brittle. Bumping them can break the needle off, if it hasn't already vibrated off form use/age
Same applies for the gauge needles on the "gauge package" cars, especially the speedo needles.
Well that explains it, I was guessing that the needle had broken off but I wasn't sure entirely. Thanks 👍 .
Now that you mention it I’m not sure where that needle is or how it would move about because I don’t see how it’d be connected to anything. However, it did seem like something could be missing in there. Lol, what can I do, it’s low on the priority list.
I had an 80 Malibu wagon that the previous owner had glued a finishing nail to the selector to replace the needle. It worked, but as I found many little things he "fixed", I quickly figured out the guy had no business working on a car !
