I did not change the lines or the rails with the new engine. I didn't have any suspicion of them.
Here is the filter (from e85 freaks):
I’ll pull them out this weekend and give them a tap 🙄.Try pulling the pump set out and tapping on the pump with a hammer. Sometimes they will stick after being left open in the air.
The gunk very well could have come from the fuel rail. Does FL have 5 or 10% ethanol in their fuel from the state? I have been told that because straight gas is very 'mild' the gunk that normally accumulates is cleaned out when you switch to ethanol because it is an alcohol and cleans out the goo. Ethanol doesn't degrade stuff as bad as people like to claim, but it exposes problems that otherwise would not be exposed on a pure gas car.
Food for thought.
FL has 10% ethanol content in pump gas. The car has mostly seen e50-e80 since I’ve put it together. I’m going to do better about flushing more with 93 to hopefully prevent issues like this in the future.
Grab a 20V cordless battery and jump them directly. If they don't move, they toast. But, both at the exact same time seems highly suspect.
