thanks man! 8)1984 Big Block H/O said:PS-- Kev, that Monte of yours is going to be awesome when it's done.
I think Extreme is building 4L80s now as well. IIR the two guys from Extreme and CK used to work together, or one for the other. Fairly sure I read that somewhere when I was looking for a trans builder. I went with Extreme as he was local to me at the time, since then he has moved to NC. He will also modify your stock valve body to the same as the GNs BRF. Make sure you keep your speedo drive bullet with gear, retainer, and bolt. If you order a new trans from him, be sure to ask for one if you are keeping your cable drive.Kansas Bu Wagon said:Have you thought about a 4l80e?
