1984 Oldsmobile Cutlass Supreme Brougham
A polaroid seemed appropriate.
Turns out, even if you get all the specific bolt spacing/diameter specs right for the engine fan clutch, there's one parameter left, never clarified when you buy the clutch: the length of the water pump shaft w/r to the clutch shaft "hole". Well, that is fun. Luckily, my car came with a spare water pump (thanks dad!), and the water pump currently on my Cutlass is worn out (squeaks when turned by hand), so I trimmed the shaft on the new pump & will install it on the car 🙈🙉🙊
...and then the new fan clutch will fit.
It turns out, my TH-200-4R speedo gears are such a mismatch with the car's rear end, it will not even reach minimum speed to trigger the lock-up module 🙂
so, let's stash this until the 3.42 differential is installed.
Reactions: olds307 and 403
Sooo... Removing the carpet revealed the rust... 🙂 A few holes, nothing major, not pretty, but I have seen worst.
Reactions: 5spdCab
Would have loved to work on the floor, but right now, weather is very rainy around here.
So....
Worked on the seats instead. Converting the manual 45-55 seats into power seats, using Eldorado power seat rails. Was already partially done for the driver seat, now aligning everything.
I had to cut the side of the seats, but it turned out alright, using a metal plate hidden behind the seat hide. Looks almost OEM in my book, so OK
