Re: 1986 Olds Cutlass Salon Thread(About Time!)
I will be going back to a stock shifter if i can find one,i have the stock cable for it still and the transmission arm is off the 2004r that was in my cutlass so everything should be bolt on.Right now its very hard to shift and the force needed to shift the transmission from 1st to second is so much that you miss second completely and throw it into third.I will also be converting over to a stock automatic valve body and put a transkit in it sometime unless i can figure out the problem with the cable/shifter. I also need to get a plate to cover up the big hole made for the aftermarket shifter so most definitely i will be going all stock again in the near future.
The valvetrain is roller,solid roller lifters from mondello and a lunati roller cam.
I also forgot to mention i had to cut the middle section of the hood bracing out to fit the air cleaner since it was hitting it.
