307 non computer controlled timing.
DoubleV
2,154
407
83
Medina Ohio
Your engine doesn't know or care if it's running on the computer or not. The engine itself was designed/tuned to want X timing and Y fuel. Hypothetically, provide it with the same air/fuel and timing the computer did and it will run perfectly. Change those parameters and things can get very tricky.
And still don't rule out carb issues. Do you have any stats on your new carb? I don't know anything about Jet carbs but I would be very surprised if it was taylored to your specific engine.
Jimmy
216
469
Gulfport, MS
I understand that things can get tricky but the parameters are changed when the computer was eliminated. I also understand that there could be an issue with the carb, however since olds did not make a 307 without the computer controlled it is logical to think that the same initial timing may be different than computer controlled timing. That's the reason I asked if anyone had any idea on timing without the computer. This is the carb: https://www.summitracing.com/parts/jet-32002
DoubleV
2,154
407
83
Medina Ohio
My opinion is the parameters have not changed at all. Your engine is exactly the same as before. Decomputerizing doesn't suddenly make your engine want crazy different fuel or timing.
8,828
7,786
X2 on manifold vacuum. You are completely wrong on the 307, Canadian cars were non CCC til 86. I owned one and worked on quite a few. I saw anywhere from 13 at 1100 to 22 at 1100 for timing specs. The one with 13 at 1100 honestly ran the shittiest. My car had 16 at 1100, 22 lost fuel economy, I think it ran best at 17 or 18. But remember it would have a 30 degree vacuum can, that is a ton of part throttle timing. The mechanical curves were no doubt different amongst them. The carbs were calibrated ridiculously lean, just freeing up the exhaust and removing the EGR made it stumble and backfire at part throttle. The only 307 have made ping was when I put very lean secondary rods in a Qjet, sounded like marbles were being thrown in when the secondaries opened.
