403 Head Question
Did you hit water jacket?
Using 2"/1.625" valves? How much porting time do you have on the exhaust side? Nice job BTW.
None really used a bore cutter to hog them.
Not going nuts with them. This is a driver.
They will flow great for up to 400HP
I should be around 325-350
It's a "cruiser".
My mind was thinking short stroke + halo + big valve heads = 7500 cruisable rpm.
If it wasnt for the webbed block
It could have been the best engine ever built
huge pistons short stroke a real screamer
Yeah, God bless the late 70's. Surprised your Cad V8 wasn't lightened as well. Pontiac also stripped meat out of their bottom end on the 400 in 77. The intake port is Ok on the 403 4A heads. The exhaust port is a different story pretty constipated, even the J and 8 heads are better after a bowl hog. Talking 195/119 stock. Hopefully the 1.625" valve and opening the bowl at least equal stock early SBO heads.
The 472 and 500 were always heavy duty. By the time the 500 went away and the 425 took over the lightening had begun.
Lots of people are building 425s. I have no idea why. Must be for fuel economy 👍
