just a real quick glance, the c6 vette has the same ebrake shoe number as the ls1 fbody so I would make the assumption based on that that the ebrake drum portion of both rotors are the same diameter.
Given that, I did some quick theoretical drawings and Yes... totally plossable.
If we make a 1/2" spacer between the backer and axle tube that will put the ebrake stuff in the correct position.
Cut the stock PAB mount off the LS1 backer. This will allow clearence.
Then we can make a big "C" shaped bracket that fits around the axle tube to the oposite side of the axle flange from the LS1 backer plate. This will act as the new PAB mounting plate.
I will email you the quick drawing I did and will post the pic here when I get home (work restricts what I can do)
sh*t, this means Im buying zo6 rear rotors now!
