80's called they want their paint job back 82 regal
39F
530
602
Pittsburgh PA
So after posting in the new user section sharing some other info and trying to decide on a motor/general game plan ,here it goes . So after selling my 79 Malibu after much frustration I been looking for another car and not find another Malibu or Cutlass ,I stumbled upon this 82 regal ,my last car already been kinda hacked up alot of stuff not right had body rot I did not want to do the same thing again, so I went check this regal out great shape appears not to be all stock besides the wheels and tires .So the plan is to have a car I can drive to car shows go have fun with.
39F
530
602
Pittsburgh PA
So I started by removing some unneeded things like AC box off the firewall and old motor mounts still need to pull out the old fuel lines and fuel tank
39F
530
602
Pittsburgh PA
Far as motor goes I got a 427 big block I had in my old car it was 12.5 to 1 ls6 rect. Port heads strip dominator intake 630 lift 290 at 50 duration the motor ran extremely well, I left a car show and drove to a spot with decent concrete did a burn out then went to lunch the car dead hooked and scattered the old transmission th400 manual valve body 3800 stall . Anyhow the bottom end is a 80s 454 block, 6223 forged crank, Crower sportsman rods,and TRW 40cc domes I'm removing the big cam and putting in comp cams 515/520 lift 230 at 50 duration left over from another motor . I'm pulling the rect. Ports (#026) with 110 cc chambers for a set of large ovals (#781) with 117 cc chambers I just had them done all fresh 219/188 valves I gave them a port job (not done yet) ,after doing some math I can be down to lil under 10.5-1 if I swap heads and run a thick had gasket ,I also want to run a small plate system I got . So I got a performer rpm intake and a strip dominator intake both are oval port intakes
39F
530
602
Pittsburgh PA
It's a no air gap rpm
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
Looks clean!
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
That paint would make a sweet sleeper
39F
530
602
Pittsburgh PA
Motor is finally together decided on to run the strip dominator due to getting pissed at the performer rpm cause a carb stud snapped off .Also dug the trans out got to figure this whole f body clutch master cylinder
39F
530
602
Pittsburgh PA
I got two bell housing to use one is a 69 Camaro other is from a 65 nova the nova one looks very similar to a gbody one how the pivot ball is lower
