liquidh8
Looking good! The seam sealing them damn doors is a time consuming affair. I used painters tape over all the joints to get nice clean lines. Ughh, a lot of guys never put it back.
Thanks, Jim!
I put fresh sealer where ever it was removed. Nothing like rust stains to compliment fresh paint! 😱
Removing the old sealer took a lot of time... Definitely needed to be done though.
The stuff I removed was of such varying consistency around the car that I decided to just completely wing it putting it back on.
I've been leaning pretty heavily on the "just like the factory did it" state of mind as a way to excuse my short cuts... lol
On the plus side, with the exception of a few small spots I'm holding off on in case I need to shoot more primer, I'm done with the seam sealer.
I'll also run a bead along the top of each hinge once their locations are finalized.
Just like the factory...
Blake,
Sealing the hinges is a good idea...especially seeing how badly they rust over time. But sometimes the seal is responsible for crap being trapped there.
Blake, I'm doing this in my 78 monte, can you elaborate about the seam sealer in the doors a little more about where you seam sealed them? Also, what seam sealer brand did you use? Was that the same sealer used throughout the car? Where did you get it? Thanks for all this- great thread man, like reading all your wisdom
