Dust cover bolts?Did you have missing bolt holes in the block for some of the trans case mounting spots? I bought ARP bolts for mine and have 2 or 3 "extra" bolts leftover.
Nice converter btw
Nice converter btw
Nope.... those are on the bottom obviously.... A few on the top of the trans bell housing and corresponding holes are not on the block? I think I have 5 bolts installed plus dowel plugsDust cover bolts?
I had two bolts extra. Only one used spot on the bell housing though.Did you have missing bolt holes in the block for some of the trans case mounting spots? I bought ARP bolts for mine and have 2 or 3 "extra" bolts leftover.
Nice converter btw
Last sentence lost me..... ? but that's easy to do these daysI had two bolts extra. Only one used spot on the bell housing though.
Me tooNope.... those are on the bottom obviously.... A few on the top of the trans bell housing and corresponding holes are not on the block? I think I have 5 bolts installed plus dowel plugs
I meant only one mount location unused on bellhousing.Last sentence lost me..... ? but that's easy to do these days
Got it. Mine must be an anomaly.Me too
Thanks! Will get some asapI used DEI's cool tape for my brake line, as well as shifter cable where it comes close to the header. The tape is good for 400°F direct heat, and I think up to 2,000°F radiant.
Most of the parts stores have the cool tape on the shelf in the "performance" aisle. I'm running Taylor wires and absolutely no fitment/clearance issues. They're close in a couple spots, but not close enough to warrant heat shields.Thanks! Will get some asap
Did you have the issues with plug boots and headers as well?
