Fired up the welder
And on to the clutch pedal! The John Bzdel pedal is nice but I plan on driving this car quite a bit and I am not a fan of no firewall reinforcement, no provisions for a cruise cutoff switch, ect. GSI interiors is $520 so nope.
I picked up an 86 S10 pedal and found out there is a ton more to the system than anything you can buy so I ended up getting an entire brake and clutch assy out of the same S10 style.
The G body brake assy is on the right, S10 on the left. S10 is way too big to fit in a G body but the pedals are the same length. S10 pivot is just moved 2" farther from the firewall.
Nice thing with the S10 clutch pedal is it has 1 big bolt, 2 spot welds, and 6 rivets and it comes off. And it most entirely just bolts on in perfect location to the stock G body brake pedal. The reinforcing rods that go to the firewall are too long (by 2" or so) so they need to get cut down. I cut a little material off and replaced some of the rivets with bolts. Its getting there.
S10 brake pedal bottom, G body brake top.
Looks good!
Looks good!
