Too much powah
Not enough stud
I was thinking maybe it just bent the axle flange locally but nope, the studs are bent. They were about 80ftlb checked with my digi torque wrench.
1/2-20 screw in studs incoming
Too much powah
Not enough stud
Where u using conical lug nuts?
100ftlbs too much on a 12mm stud
You should be at least 100 ft/lb, what does your math say when you go higher?
I'll need to check. It's borderline.
I can get to 120 safe on 1/2-20 and they are cheaper than anther set of 12mm oddly enough
Conical is a big reason they bent for sure. 1/2 might hold up, especially because they will likely be made from better material, but eventually they will bend too.Conical yeah. My 15x10 drag steelies and 17x9 street wheels both use conical
u're an engineer but trade, so smarter than me. Thing is though 1/2" is
