What were the rpm’s when you shifted and where did it drop too?
Congrats man - well done!! Hopefully you can top it today!!
I tried shooting for 7000 shift RPM but not having a proper tach that reads to 7 makes it hard. The original GP tach I use only goes to 6k and using a combination of a shift light and guessing somewhere beyond 6k is what I use and it's not really enough. Just not a consistent way to shift. I need to get ready to shift a few 100 RPM early and I guess to fast most of the time. Looking at my logs I end up shifting at 6600-6800. I remember I had a number of 7k limiter blips when I was at Brainerd a few weeks ago and I tried to avoid that, probably to my fault. The RPM drops to 5000 on shifts when I shift at 6600 roughly so it could get to 5400 if I'd actually shift it at 7000. Power wise I don't think I am giving up much but it's probably more of a longevity/kind to the bottom end thing.
IAT's usually start at 125F at the start of the run and on 10 psi climb to about 165F. On 11.5 psi it climbs to 175-180F. I'm getting near the point where methanol injection or something to cool the charge wouldn't be bad, but as I am already getting deepish into the too-fast for without a cage, I'm not sure it's useful or necessary as I have no desire to cage the car. I also get worried about a stock F body t56 living at 625+hp
I also noticed even though my lugs were tight I'm starting to bend the studs over. These are morosso 12mm press in, I need to pull the rotor off and see if they are bending the axle flange, the stud itself or what??? These axles also have provisions for 1/2-20 screw in studs which I'll probably swap to. I wanted to keep 12mm to match my fronts but apparently I am beyond that point. They also make 14mm studs, I need to see what will fit my Year1 and 15x10 steelies.
