BUILD THREAD 86 GP 2+2~Blown 6.0
Side 2 done.
Side 2 done.
Is there nothing you can't chuck up in that lathe? Awesome work. Lookin forward to seeing the booger welds. 😏
I'm assuming you're going to preheat the center section before you weld it?
Tubes are welded to the housing. Little progress every night!
I was lazy and watched the new avengers movie last night AND the last episode of game of thrones tonight (gasp I am loosing productivity!)
Asked my engineering/welding buddy with 10 years of experience in aerospace TIG and sub arc mig welding for trailers how you should weld cast iron to mild steel. He said keep the cast under 300F, dont preheat, work around to not warp anything. Nickel copper arc rods are ideal but I wanted mig so Stainless wire was a good second. Thats what I did. Preheat would be good if I welded it in a rotating table if you wanted to do it in one shot for more production environment and cool slowly in a sand put but I didnt want to deal with that.
Looks good so far.
Lt. Diff, you ain't got no legs!
Look at them boogers!!!
Looks pretty good to me! Definitely better than I could do.
Been dealing with wagon issues but I did jig the axle up in the mean time. I also finally hunted down argon so I can get to welding next week! Just need to turn some bushing holders for the plate, weld the plate, buy a posi and should be in business!
Well I turned my bushing supports for the UCA mounts and welded those in yesterday. I also pressed bearings in the posi diff I bought and swapped the ring gear over. Pulled the pinion out of this rear and found I got the wrong seal so I ordered a different one. Bearings looked good though so they are going right back in. Also bought a 1350 factory forged input yoke out of a hummer h2 for $60 off ebay.
I have spherical UCA bushings on order and new wheel studs for the moser 30 spline axles I have.
Hopefully get the diff assembled tonight and in paint later this week?
I want adjustable spring pockets so I can dial in ride height so I have some parts hunting to do today. I'll see how this works 🙂
117529
117530
Something like this maybe?
Thats a jack bolt / cup to weld into the frame.
He wants something like this.
https://www.speedwaymotors.com/AFCO-Adjustable-Spring-Spacer,49203.html
The only issue is it only fits 5" springs, 3rd gen camaro springs are pigtail on one end and 5" on the top
Yeah I almost bought those afco spacers but decided against them since a) the G body spring has a 2.5" pigtail and b) (the real reason) there isn't a good way to adjust them up and down since there is no wrench slots like a coilover or a normal hex.
I saw a G body guy with a quick 9" that had those spring adjusters in it and it was real nice for towing trailers and drag week stuff.
I have a design sketched in my brain using some 1" threaded rod and some nuts/washers that should work as good as those afco ones but allow stock style springs and a normal wrench to adjust height. I just gotta find some giant washers!!
Reactions: Northernregal
