HUGE UPDATE!!!!!!! Y'all know I've been fighting the high idle issue, so been reading and reading and reading!!!! Did some tests last night and everything checked out.
Well, driving down the highway this morning I had an AHA moment!!! The Holley intake requires a 3bar MAP sensor, but the loaded tune is for a 1bar MAP. My theory was that as soon as the engine hit idle the ECM couldn't read the MAP signal and spiked like a vacuum leak would do!!!!
So, after consulting with MHM it was determined I had to make changes. Luckily I had my TPI harness and 1bar map handy, so I swapped the sensor and pigtail over, rigged it with a tee fitting, and BAM!!!! Even squeezed in the time on my baby's 5th birthday!! Sucker sounds mean azz hell with the cammed 5.3 and open headers!!!!!! There are a couple minor leaks to address, but let it get up to temp and idle is steady, oil is 50psi, and the stainless headers are turning which is awesome!!! More tuning required, but here y'all go!!!!
