I ended up just buying some stock replacements, and relocating the power window switches to the lower door panel next to the lock switches, for a little cleaner look. I would like to see what you have in mind, as my Cutlass Aero interior will start in a couple months.
Decided I need to keep making progress even though I haven't been feeling great today. I re routed some wiring, moved stuff around, and muscled the dash in! A YUUUUGE shout out to Hutch and his dash removal video or I'd be sitting here scratching my head still! It's been years and I forgot alot of it!!!!
Anyways, it's about 70% bolted in as of now, gonna hit it again tomorrow evening.
Been working on the dash all evening. Got alot more old wiring cleaned up that I forgot I didn't need, got the dash completely bolted down too. At this point the headlight switch is mounted (I know it's easy), and the gauge cluster is in. Gonna test fit the glove box shortly to see if it clears the ECU, then keep moving forward.
Been working on the dash all evening. Got alot more old wiring cleaned up that I forgot I didn't need, got the dash completely bolted down too. At this point the headlight switch is mounted (I know it's easy), and the gauge cluster is in. Gonna test fit the glove box shortly to see if it clears the ECU, then keep moving forward.View attachment 132010
Alright, last pics for the evening. My back is frickin killin me from crawling around inside this car all evening! The glove box is in, needs minor adjustments, pass side trim installed, the gauge surround is loosely screwed on for now. I need to make some sides for the cluster, and check all gauge functions before screwing down for good. Let me know what y'all think.
