Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
Yeah, it's not cheap, but it's good stuff and has been around for awhile. I use it on my dash and plastic parts as well. It's not greasy like Armor All. Which reminds me...I need to pick up more myself. Most stores don't carry it, but I thin Pep Boys stocks it.
Lexol leather conditioner has been around for ages.
I guess you're going to split the lenses to put LED circuit boards in?
Still debating on doing the LED swap. They are $230 vs $40 for led bulbs. I already have the led 3rd brake light. I tried splitting them last night after soaking in scorching hot water, but 30 year old plastic is brittle!!! I tried using a razor blade to cut the caulk and that sh*t is like concrete!
12,176
9,795
Yeah, I could understand the fear of screwing up a good pair of lenses. They don't come by too easily these days.
I might also consider LED bulbs...the LED circuit boards are alittle too rich my blood.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
For sure Jack. I've hunted around for a good set for several years...both NOS and very gently used and most used sets are going for $300+/pair:eek:!!!!
I figured I'd try to make mine as nice as possible and if down the road i come across a good deal then i will jump on it. Luckily, my cutlass has been decently taken care of over the years....besides the rust most of my oem parts are in great shape! Heck, my 30 year old dash has one little crack on a corner and that's it!
O. D. Showtime
3,008
3,539
Regina Sask. Canada
Scott I'll watch for a pair for you....I picked up the pair pictured below last year. They were in great shape...I had a standing "order" for a nice set for a member so they didn't last long...
and my selling price is no where near $300....
Rktpwrd
Builder of Cool Shjt
4,177
23,956
Calgary, Alberta, Canada
The lenses are looking good Scott!
Just a little tip for ya:
I refurbished the ones on The Juggernaut years ago. I didn't want people to be able to guess the year of the car by the date codes stamped on the taillights, and didn't like those little tiny letters and numbers at the bottom either.
So as already mentioned, I wet sanded the face of the lenses with a block until they were perfectly smooth. This also took care of the minor surface scratches.
Here's the tip tho: If you have access to a full size electric polisher and pad, you can polish them back up to better than new in short order. As mentioned also, wheel polish works good, but also rubbing compound does too.
In fact, you can damn near treat them like a painted surface. Wet sand, then polish with rubbing compound, fine compound, swirl remover, etc etc.
The difference is, with the polisher you can put a little bit of heat into the lenses which helps break down the polish, and enhances the shine. Just be careful not to put TOO much heat into them, as the plastic can melt and smear if you're not careful. Low speed, light touch, and keep the heat low.
Also like paint, when you're done, a coat of wax helps to protect all your hard work.
I did this process on the 'Naut's taillights probably 15 years ago, and they STILL look better than new!
At any rate, looking good my friend. Keep up the great work. Looking forward to what you've got planned as far as the "little modification" on them!
Cheers
D.
SoFloG
1,113
1,269
South Florida
You could also shoot some clear on them and wet sand and buff to add depth, but I prefer to just polish the sh*t out of my lenses. They're looking good tho, progress is progress!
liquidh8
Scott, I'm with Donavan, I treat the lenses like paint, sanding and polishing the same way.
Sent from my Z981 using Tapatalk
12,176
9,795
I also agree with the "D-man" and Jim on this...you treat it like a painted surface. A little compound after fine sanding the surface goes a long way. It's amazing how well they polish out. I've even used Weinol metal polish, which is a fine compound.
Deep scratches?....that's another ball of wax. It could probably be clearcoated with urethane, or something similar., and then buffed out again.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
Cheers
D.
Thanks guys for the advice! Once i get done doing some subtle mods to the emblem areas, and i feel that part is done i will rework them as painted parts. Luckily, i still have some cushion time before the cutlass gets its bath of color because i realized yesterday i have more parts to prep than expected! One thing at a time, check off, move to the next!
Clutch
5,189
10,913
Brick NJ
It never ends I don't think there ever really finished. I also treat lenses like painted parts at work insurance companies won't always pay for new lights and I treat them like I'm doing body work if there really bad I grab a da with 220 or even 180 nock out the bad spots and drop to a finer grit until I'm wet sanding with 3000 then I buff them out just like a bad paint job. It's only a taillight don't be scared
  • Useful
