98~05 Blazer brake upgrade! DONE!
Chris Chow
15
26
Nor Cal
Thanks. I'm converting to hydroboost. I changed the combination valve and it was marginally better. The 86-87 Buick Regal turbos used a powermaster MC setup. The accumulators are not life-long parts and will inevitably lose pressure. Rather than buying a 200.00 accumulator, I'm going to convert over to Matt Sweeting's hydroboost system and use a Wilwood MC with a 1 1/8" bore.
Streetbu
Know it all, that doesn't
3,746
11,630
Central NY
Chris, the part number that everyone says is ideal and works well is an AC Delco 18M974. It has a 1.0" diameter bore, correct side and threads for the brake lines, and a screw on brake fluid cap. Here's a RockAuto link. I just got one for my car but have too busy to install it yet.
https://www.rockauto.com/en/parts/acdelco,18M974,master+cylinder,1836
Griffin84ss
275
187
Corinth Ky
Geezy24
Nov 18, 2017
60
147
33
Does this bolt directly up with stock brake booster?
The stock mc works just fine, I swapped to a 1” bore Wilwood MC only because I got it dirt cheap new.
Blazer spindle
Blazer hubs ( new)
14 corvette rotors
6 piston c6 z06 calipers
Stops on dime! ( Priceless)!
  • Wow
Streetbu
3,746
11,630
Central NY
Stock master works, but pedal is slightly lower than usual and I'm picky LOL
Geezy24
Nov 18, 2017
60
147
33
Wasnt on mine, before the switch to the wilwood. If its low then its probably the Prop valve that needs to be swapped. How ever I did intsall stainless steel brake hoses.
Chris Chow
15
26
Nor Cal
Before.
Sent from my iPhone using Tapatalk Pro
Chris Chow
15
26
Nor Cal
After.
Chris Chow
15
26
Nor Cal
Current power master.
