Called Husek again. Got some more questions I had to answer and did a few more teardowns to see what shape parts I have and what may or may not need to be changed. For those who are going to use Husek, he knows his stuff, but schedule at least 30 minutes to talk at minimum. I have got him watching TV one night and in the shop another night.
Rebuilding a unique trans like this and dealing with the rebuilders to source parts does take an investment in time.
For my purposes more than anything-
I have a 10 spring direct clutch retainer. Performance stuff got 16 springs and I am supposed to change to a 16. Husek makes new 16 spring ones however if you are in a pinch and have an extra 200 sitting around I don't see why you couldn't rob 6 springs and snap them in.
I have a steel direct apply piston vs. aluminum which is good
83+ 2004r have a hardened sun shell, apparently the rebuilders just take your old one on a core charge and if its not an 82 they just send it back doing nothing. Sounds like a scam.
The Direct center support, drum, and pump bushings take most of the wear. Husek only changes the back ones if they are bad, the back half of the trans is probably fine but im just going to order the entire kit
My direct drum has .0015" step on the first sealing ring groove, which I think is reverse. It's probably OK if I just run a hone through that to clean it up as even if I get a bit of leakage it's only when the trans is in reverse
A CA valve body has a #G TV valve, #14 1-2 valve, #15 2-3 valve, and an #F 4th valve along with a separator plate that can be used. It sounds like Husek has some half assembled BR GN valve body cores that he can use part of my CA valve body springs and valves to piece together. It's expensive at $450 but he swears by GM valve bodies and basically won't put a trans-go in. The only way to get a complete valve body is to trade in a core for parts. He said he has had the OEM valve body springs repopped that he changes back to stock if a trans has had a trans-go shift kit already put in.
I've been spending a few hours a night for the past few days at my computer desk digging through the parts diagram, the CK book, my notes from Husek and trying to decipher what parts I need.
Cat has been a help
The telescoping gages I picked up are coming in handy.
