The terminals never corrode and they never barf acid on your battery tray. Those are the biggies for me. No lead acid mess.I guess I'm too cheap to consider one.
What is the advantage supposed to be over a standard battery other than additional reserve amps without dropping voltage at the same rate of a standard battery?
Also supposed to be better in high heat environmentsThe terminals never corrode and they never barf acid on your battery tray. Those are the biggies for me. No lead acid mess.
In our case the Cobalt uses a trunk mounted battery. It has a vent tube that goes out the bottom of the trunk. At the time no one made that battery but AC Delco and it was a Stealership only $300 investment. So I got the Odyssey AGM for half that and never worried about acid fumes in the trunk. By the time the AGM dropped dead Sears offered a Die Hard model for the Cobalt and I got one on sale really cheap. But Sears said it was in stock and it wasn't even within 100 miles of me. Another Sears story for another time. So far so good though. Anyway AGM and gel-cell was developed for aircraft because they can be mounted in any position without fear of spilling acid. But because of the no warning issue they use two for redundancy.What is the advantage supposed to be over a standard battery
Good thing. If you replace it today, you'd be lucky to get 13 months out of them. I don't know if they fixed their sh*t lately, but there for a while, those were some crappy azz batteries. I wasted too much money on those things.I have a red top Optima battery in my cutlass never had a issue with it. it is 13 years old!
