Before & After 80 G/A Grills
Poncho61
Mar 25, 2013
87
Peoria Illinois
I like the mesh. I'd like it more in black. Whats under the hood? Stock engine? That mesh, even with pencil size holes is a huge airflow restriction. It may be fine to cool a stock engine, but anything built may have some issues on a toasty day.
WhiteTiger
13
21
Carroll Iowa
The Motor 400 w/ Warrior Racing Products Cam duration @ .050 intake 212 and exhaust 225 lobe centerline 116 lift w/1.5 rocker .408/.407,shorty headers,66 Alum Tri power,Custom work to Water Pump Plate,Stock 5 blade fan with custom fab adapter/no clutch fan,180 Thermostat.
This summer it ran 35 min idle to wide open Hot laps,97 outside temp,185 temp on the gauges one in each head and one on the intake.With NO :puke:ing
Brother Al
243
12
Westfield, Mass
Out of curiosity, where did you source the honeycomb expanded metal???
WhiteTiger
13
21
Carroll Iowa
Out of curiosity, where did you source the honeycomb expanded metal??? by Brother Al
Pontiac started to use Honeycomb on wheels in 1971 but on grills in 1976 Trans Am and more Pontiac after that.The honeycomb I used is the same as on the 1999-2002 GTP hood Louvers.I started Customize all my Pontiac's in 1976.
liquidh8
I would like it black too if it were mine.
Looks good, good job.
clean8485
2,864
2,162
Ontario, Canada
White Tiger, I think that what Brother Al would like to know is the name of the supplier from whom you obtained the honeycomb material that you used to customize the GA grills.
L.A.X-RATED
1,385
385
83
people,PAY ATTENTION! the man gave the link of where to obtain the mesh when i asked him???!!! :shock: 6th post down.
Brother Al
243
12
Westfield, Mass
White Tiger: yes, very familiar with the Poncho Honeycomb theme, and have a few ideas in mind for the '79 LeMans I'm buying. Sorry about the repost of the question, see below. I have also seen Ford using a honeycomb theme in recent years, and of course the "Super Duty" moniker.. (shame)
clean8485: thanks for clarifying my question.
L.A.X-RATED: I did read it... twice to be exact. Unfortunately, my phone did not display the link... may have been the Wi-Fi I was using at the time. The Beauty of Technology.
Oct 24, 2013
4
Hello: Hope you saved the pieces. About a half dozen of those little plastic pieces would go a long way to
fixing my 80 Grills. Sure enjoy this web site. Passenger side an easy fix. The driver side frame is damaged
in the upper outside corner. Trent in Los Angeles.
