looking for advice on cam for my lq4 looking for that muscle car choppy idle and of course more hp. I plan on getting a set of 799/243 heads to bump up compression a lil bit. Right now has 317s. Im run n a stock converter but i do plan on get n a converter to work with cam. Rear end will be 3.73s. I have a holley 750 on it also with a victor jr intake. Let me know what u guys think
Know your valve lift limitations prior to selection. Also understand that lumpy cams kill engine
vacuum and you may get a hard pedal at idle speeds. A vacuum brake booster would be in order.
Are you going to run full exhaust with headers ?
There is so many LS cam grinders out there its easy to get lost. Ive been doing a lot of research for my 6.0 build and basically narrowed it down to an EPS, CamMotion, or Brian Tooley Racing cam. A lot of the comp ones have records of being "whiney" and use lobes that can be rough on springs.
Custom grinds are really popular too and really no more expensive. Your combo is really simple enough that any off the shelf single plane or carb manifold cam is going to be good enough. Any decent, well known shop cam is going to be within a few HP of each other.
I do have longtube headers and i have flows but not sure if i gonna do turn downs or all the way to the rear. As far as valve lift limitations thats kind the thing i dont really know much of so any advise and help is much appreciated i do plan on change n valve springs to match cam not sure what else exactly is needed
You are right bout so many different cam choices out there thats kinda why i thought i would ask for some help. And alot of cams seem like they are tailored more for efi.
I did lifters, pushrods, springs, trunnions, and a custom grind from Cam Motion for my single plane intake LY6. I was told you need different cams for efi or carb, and cathedral port or rectangular port heads. My custom grind didn't cost much more than an off the shelf.
