our cars are not all metric
Actually I change my original answer to this. Half metric half standard. Has anyone ever made sense of it on these cars? It seems like most of it is metric but then they'll be that one bolt that's standard.
Haha it should be the top pet peeve of all of us because it comes straight from the factory that way.On my olds the bolts that held the trans mount to the trans were metric. The but that held the mount to the cross member was sae lol
What I read is its perfectly legal to supercharge your engine as long as its c.a.r.b. approved.....which the factory m90 is.
Technically its my thread me and you are highjacking so its OK 😉You still don't quite get how things work here. 😀
A factory supercharger is only "CARB approved" for those applications that had that supercharger as a factory option. For the 3800 that means FWD, since there were no supercharged RWD applications in the US.
That's why I asked where you read it, so I could go look at the exact claims being made. It's natural to assume if something makes sense it must be ok with CARB, and vice versa. It ain't necessarily so. 😀
Basically, I'd want to hear this one from a Referee.
EDIT: We're kind of hijacking the thread in a different direction with this ongoing bs ....
My Jaguar (XK8) had a mix of Std and Metric bolts from the factory into the mid 2000's. At least on a G-body they usually use bolts with headsizes that take either metric or std (like 13 &14) and just the threads are different. On the Jag, bolts are between mm's like 11/16's, so a a 17 doesn't fit and an 18 rounds it off..
