Blazer brake upgrade question
20,397
I guess I should have measured. The swap is done on my car and if there is a difference it's not evident to the naked eye.
If it gives you a wider track it will have a better chance to rub on the sway bar and the plastic wheel housing in the back on full lock. The F body spindles I use put the wheels out about 1/2" on each side and that was noticeable on a full lock
7,989
18,702
A wider track would make it more prone to rub the sway bar? Seems like the opposite would be true.
20,397
It's similar to the effect of installing a longer pitman arm. You get more travel with the same input. I should point out I forgot my set up is different. I have no stops in my steering box. The stops on the lower control arm didn't help so I removed them and put adjustable stops.
UNGN
3,048
3,264
Southlake, TX
Wider Track is less prone to rub the Frame and sway bar, but more prone to rub the fender lip and back of the inner fender.
Choosing a wheel offset that DOESN'T rub the fender lip and back of the inner fender is what causes more frame and sway bar rub.
I run 3rd gen F-body "rear" wheel offsets (+16mm) on the front because "fronts" (zero offset) rub the fenders.
81msw79
391
125
roselle park , nj
98 and up s-series blazer 2wd is the only truck you can pull the bakes from.any trim package of the blazer will have 4wheel disc. the pickups no matter the trim package will have g body type spindle with single piston calipers in front and rear drum. dont waste time looking at any pickups.
the stock blazer spindle will not change your track width. however belltech is the only company making blazer drop spindles. they will push your track width out approx 3/8" - 1/2" per side
L67ss
1,350
420
OK after reading I guess not all zq8s had 4 wheel discs. But all they plain s10s with zq8 RPO I've seen had them
oldsmobile joe
2,067
3,053
mpls
Hey everyone ,
Two more questions, do the Blazer and the S10 use the same spindles, and when you upgrade to the blazer spindle does it push your wheels out or does the track stay the same.
Thank you in advance .
i have done the blazer spindle swap using an adapter kit from Kore3 to fit corvette c5 brakes. there is no appreciable change in front track width.
UNGN
3,048
3,264
Southlake, TX
That is good to know because the Stock Spindle C4 / LS1 / C5 brake conversions definitely widen the track between 5/16" and 3/8" per side.
