Depending on how you lift the front, a brace like the purple one, on the front somewhere might not hurt. It should stop the front from trying to spread.
How do you plan on lifting the body up? A bunch of buddies or lifts/jacks? I was just wandering if the backseat pan is already bracing the purple area. There is a rear crossmember there too. View attachment 151868
Its welded to both inner rockers. Then up front you got the firewall and whats left of your floor to hold the front together. Im thinking the purple line would be more helpful if moved forward.
I think either of those would work fine especially if you put the door braces in. Once its safe and solid on the 4x4s i would think you could remove any braces in your way.
