Buzzer will randomly come on..
MalibuHacon
122
6
26
Norway
On my 1980 Chevy Malibu the buzzer randomly comes on, and stays on! it is very loud and obnoxious, and i think it might be pulling some battery juice as well.
It will disappear when I put my key in the ignition and turn it to the first click and turn on again once i take it out.
It will get louder if I put on the lights and interior lights.
Whenever it stops it will come on if i open my drivers door and shut off when i close it, the little button switch in the door seems to work
Whenever it is not on it will come on as it should when lights are on, and gauge lights.
It would typically disappear before today whenever doors are closed. but it would randomly come on
Today it got worse and it won't shut off, it finally shut off after i took the key in and out of the ignition probably ten times, opened and closed the doors, and flicked the lights off and on several times.
After the success I left the car, when i got back after a few hours, to check my battery it was on (you can even hear it through the car) .. my new battery has very bad voltage, and i'm having a million other problems to fix...
This has been ongoing (happened maybe once a week) but I was always able to shut it off by putting keys in and out of ignition and turning it once...
How would I go about fixing this? 🙂
