David...you said you get a clank when you try to start it...does it start or it's doesn't engage at all?
pontiacgp said:David...you said you get a clank when you try to start it...does it start or it's doesn't engage at all?
pontiacgp said:that sounds like the starter...the rough running is something else tho
Bonnewagon said:Well, as always. It's time to get it up in the air and take a peek. Never spend money without verifying the problem.
CHRIS.O said:Are you sure the starter is tight? It moves around a lot. It looks like it is either loose or binding. I had a starter go out within a few days of buying it, it started rolling over slow like a dead battery then a clank and eventually it went to only rolling a half turn or so. What is going on with your carb now? You got the new one on there right?
