Bonnewagon said:I agree, loose starter. Something's wrong there. Maybe the bolts are bottoming before the starter is tight, and I think you should use a bracket at the FRONT to stabilize it. Most cars come with the forward bracket, then when the starter gets changed it's too difficult to replace so it gets left off. But it prevents exactly what you are experiencing. I also see an electric choke not wired up, so the fast idle will NEVER come down, and if it's set at 6,000 you see where I'm going with this. I also see a rubber carb fuel line where a steel one should be- a tragedy waiting to happen.
Where could I get a bracket for the starter?
Yeah i still have to buy the wires the + and - but they only sell as a set for like 30 and all I need is the wires, wondering where I could go to get just the wires.
But when I get the wires it will settle on the idle a lot?
That should be a steel line?
what will happen if I run the rubber line?
