my 86 cutlass salon i believe it originally had the v6 /th200 trans before i got it it had a 455 /unknown trans to me. i put in a 307 with th 350 trans my problem is getting the crossmember to line up correctly i have two different ones and they just wont line up to the frame . the bottom one if i go straight across the mount is inches away from the member. if i stagger it only one hole on each side lines up . the top one the holes line up but the mount is off any suggestions will be greatly appreciated thank you
