Crucial118's 86 Cutty Salon 307->350->406->(TURBO) Build
Re: crucial118's 86 Cutty Salon build
Got started on the hot side today. Bought some sbc tri-shorty corvette header off ebay(http://www.ebay.com/itm/350889795907?ss ... 1439.l2649). They didn't want to work with my tall valve cover's(especially the driver's side), so I had to go to the junkyard to find some stock center-bolt valve covers. Which I didn't think would work, until I cut the insides out. This also should help with my valve cover leak, due to the shitty design of the afr eliminator lower perimeter bolt holes. Turned out real good.
1979Calais said:
Nice work, I will be bring my engine to you when you are done with yours.
Thanks.
Re: crucial118's Transformation 86 Cutty Salon build
Just scored a brand new Tial 50mm blow off valve and 44mm wastegate...
hurst1979olds said:
Cant wait to see final videos!
They're coming...eventually. 🙂 In the meantime I found a good place for the -10 AN oil return, in the fuel pump block off plate. Really didn't want to lift the engine to drop the oil pan to drill and tap.
Re: Crucial118's 86 Cutty Salon Transformation Build
Couple update photos...
i've been slacking on checking for updates and i must say GATDAMMMN. i can't wait to see how this runs now.
