That is what he recommended.You're brave going with the needle bearings! Too many reports of failures. The bronze bushings are worth the extra loot.
I spoke to the speed shop and told him that I had heard some people had problems with needle bearings. He asked me which ones I wanted to use and I told him whichever type he is most comfortable with. He doubled down on the BTR trunnions although either type would work well for my engine. He has a great reputation and has done work for a lot of people I know.As long as you get a needle bearing kit with the outside C clips that retain the inside there will be no issues with loosing needles and trashing engine. But the bronze bushing ones are nice also
Ha!!! I have 862's on my 5.3....the only things the machine shop did to them was check the deck for flatness and milled a c*nt hair off and install the BTR .660 springs. I plan on punishing them as much as possible, especially once boosted.Heads with the casting number 706 (03ish to 06ish 4.8/5.3 truck engines) were semi prone to cracking. The rest of them don't have enough of an issue to cause people to bother with even looking at them close enough to see cracks. My head's are 862 casting. Widely considered the turd of the LS world. I ruthlessly brutalize them. Reuse head gaskets, TTY head bolts, hose them off with brake parts cleaner, etc. Slap them on and put the screws to 'em again. If they aren't making the oil into a milkshake then there's no problem.
