I think you'll find more power driving it around a while and watching the AFR. Then, stick it on the dyno, or better yet, make a few passes on the strip and run the numbers. That's so much more fun (& accurate, I think) than watching somebody strap your shirt to a roller.
Completely agree. Although I'm going to get mine tuned more professionally for a safe street tune on the dyno. More because I am sure I'd need a cage if I took it to a track and ran it hard.
I reread my post about a Dyno run. I guess I will do it. Just not right away. I had a Road Glide that I hopped up. I had it put on a Dyno and found 8 hp and I believe it was 5 tq. Couldn't tell a difference and I was out a couple hundred dollars. The closest LS tuning Wizard is about 2 hours from me so it would be a whole day of traveling and watching some guy beat on my car. All for maybe getting some usable power and out $350.00 plus gas.
You are staying with the factory ecu? Target 12.5 and 18degrees at peak torque and 24 or so degrees at 5k rpm and you will be happy. Mine liked that a lot. Could probably get 27 degrees and still make power up top.
