Dash light help
mobileaudio25
518
161
columbus, ohio
My lights are very dim in the malibu so i wanted to take apart the dash and put 194 LEDs to brighten it up. For some reason when I put the LEDs in they will barely light up or not light up at all but if i put a regular bulb back in the dash it is fine. I have used these 194 LEDs on multiple cars and friends cars. They are even used as my license plate light and front corner marker on the malibu. I know they are good bulbs. Any ideas?
My dimmer works fine, it cuts in and out but i can get it to dim the lights and get them bright so I do not think the problem is there.
mobileaudio25
518
161
columbus, ohio
I figured it out.... If anyone is looking to upgrade led lights behind the dash the led bulbs you need are WLED-W-120 from superbrightleds.com
their other 194 bulbs work everywhere in our car but the sockets in the dash are slightly different.
Bar50
1,180
871
Tulsa, OK
I bought a set with sockets off of amazon and they work with the dimmer.
mobileaudio25
518
161
columbus, ohio
does the dimmer work with the WLED-W-120
the dimmer does not work with the leds. I've heard you have to change out the sockets that it plugs into in order for that to work, but i may have heard wrong.
if my dimmer is all the way left and i turn it to the right it does not dim or brighten at a constant rate, it jumps around and sometimes they will even turn off and turn back on depending where the dimmer is at. Is this safe or ok? i don't use the dimmer much but if it could be unsafe i certainly want to fix it.
mobileaudio25
518
161
columbus, ohio
the led bulbs you bought off amazon also came with the sockets that connect through the circuit on the back? i don't really care if i can dim the leds or not but might do it depending on the price. do you have a link or do you remember the brand of sockets?
O. D. Showtime
3,008
3,539
Regina Sask. Canada
Not sure on the quality of that one....but the headlight dimmer switch mounts lower down the column and is activated with a rod when you flip the turn signal lever.
Dimming of the dash lights is through the headlight switch
I have nice OEM headlight dimmer and headlight switches but I'm not sure I can beat that price....match it probably + shipping.
mobileaudio25
518
161
columbus, ohio
When I move my lever on column to turn on my brights the rod does not move but I can manually push the switch. I think that the rod in the column came off of the lever somehow. Only way to fix is to pull the steering wheel and drop the column correct?
If I decided to have my lights so that I couldn't use my brights and just made sure only the low beams were on would that be ok? It Wouldn't affect any other lighting other than not having the ability to use my brights right
7,989
18,702
Is the rod engaged in the switch? You can see it without dropping the column.
