The wide intakes on Olds V8 can be a b*tch to seal. I find you need a 3 layer tall bead to seal the valley area. Hopefully they didn't use the rubber end seals, they usually leak.
I just hope it isn't the main seal or the oil pan......i don't have the skills to pull the motor out to fix that stuff.The wide intakes on Olds V8 can be a b*tch to seal. I find you need a 3 layer tall bead to seal the valley area. Hopefully they didn't use the rubber end seals, they usually leak.
If it leaks like you say it does, go out this evening with your black light and look around back there. You should see it immediately.Added the dye in the car. Will drive it for a week or two and see what happens.
I will check tomorrow when I drive it to work. I get a spot on the garage floor about the size of a dollar bill cut in half over nightIf it leaks like you say it does, go out this evening with your black light and look around back there. You should see it immediately.
That could be. I'm gonna get the black light on it tomorrow and see if the spots glowThe dye can be thinner than the oil you are using, causing the oil to leak more.
