elec fans?
MD13ailey
337
Columbia city, Oregob
i have dual ten inch electric fans in my 78 regal and i had to cut the top part of my fan shroud off so it would still hold in the radiator and then i pop rivited the fans to it. they are out of some year of camaro either a late 80s or early 90s and then i bought a contoller out of summit so they do everything themselves
MD13ailey
337
20,417
86Cutlass383SR said:
With my car being a daily driver I personally like using factory parts that are widely available when replacement is needed. I've heard people using Dodge Intrepid fans, Ford Taurus, etc.
On my car I'm using the GM f-body alum radiator with the plastic tanks and the factory dual fans. Many look down on these rads because of the plastic tanks. I figure if GM trusted them who am I to doubt. If it ever does go bad, I may get the Summit direct replacement alum rad for $289.95. Same situation on the electric fans. I've never had one go bad (and I bought them used too) along with the upper mounting and it was an easy mod to bolt to my radiator support. If they ever need replaced, I may look into either the Ford or Dodge setups.
before you head to summit find yourself a circle track speed shop to get an aluminum rad...they are alot cheaper and they fit right in place...I have an Allstar rad...
http://www.allstarperformance.com/product.htm?prod=312
86Cutlass383SR
720
6
Sesser, IL
Thanks for that link! I may very well go with one of those. Thanks!
mebe007
1,808
4
36
newport news, viginia
what should i run the tmep switch at as well. i have 180deg tstat
jerrycad472
264
16
Detroit, MI
LT1/LS1 fan from 4th Gen F-body fits well in a G-body.
ubanks2000
33
Please keep us updated because i know personally i was wanting to purchase a radiator from them this summer. But i am so skeptical about their prices. Please first problem or the first time you realize that it is amazing please reply on the thread.
86Cutlass383SR
720
6
Sesser, IL
Anybody know if the late 80's Camaro dual fans are single speed or dual speed?
