Electric cooling fans
565bbchevy
9,616
12,688
Michigan
When I pull my engine I leave the radiator and fans in there and remove my water pump which is mounted with studs and there is just enough room between the fans to slide it forward and get it out.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
dual pullers with the big block here too.
liquidh8
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
How do you mount the Intrepid fans since the mounting tabs are on the sides?
L bracket to rad support?
565bbchevy
9,616
12,688
Michigan
That's how I did mine I made 4 brackets mounted to the core support.
