MONTE CARLO Engine Advice: 450-500 whp (Stock Hood)
L92 OLDS
2,872
3,051
West Michigan
Here you go. 455HP, a smooth idle, reasonable fuel mileage, and legal in California. Chevrolet performance E rod package. I know it breaks your $6,500 budget but you can thank the liberal tree hugger's and the people of your state that voted for for them. Turbo LS would be the most cost effective.
https://www.summitracing.com/parts/...MIpqOwoYDI3wIVEtbACh2tfgB1EAQYAiABEgKCqvD_BwE
Chevrolet LT1 6.2L E-Rod long block crate engine specs and features include:
* Cast aluminum with 6-bolt nodular iron main bearing caps
* Direct-injection, spark-ignition Gen-V small block V8
* Horsepower: 455 at 6,000 rpm
* Torque: 465 lbs.-ft. at 4,600 rpm
* Crankshaft: Forged steel
* Connecting rods: Forged powdered metal
* Pistons: Eutectic
* Camshaft type: Billet steel roller
* Valve lift (in.): .561 intake/.531 exhaust
* Camshaft duration (at 0.050 in.): 200 degrees intake/212 degrees exhaust
* Cylinder heads: Aluminum, rectangular port D/I
* Valve size (in.): 2.13 intake/1.59 exhaust
* Compression ratio: 11.5:1
* Rocker arms: Investment-cast, roller trunnion
* Rocker arm ratio: 1.81:1
* Recommended fuel: Premium pump
* Maximum recommended rpm: 6600
* Reluctor wheel: 58X
* Balanced: Internal
* Engine control module
* Exhaust manifolds
* Catalytic converters
* Mass airflow sensor and sensor boss
* Oxygen sensors and sensor bosses
* Air filter
* Accelerator pedal
* Evaporative emissions canister
* Instruction manual
* Pistons: Eutectic
* Exhaust manifolds
* Air filter
* Accelerator pedal
All well and good until the Smog Nazis realize you modified the manifolds/cats to fit in your car. Cheaper to move to a new State.
20,397
DRIVEN
8,079
14,556
*CENSORED*
Earthquake? I thought California banned those.
  • Happy
Clone TIE Pilot
3,868
2,621
Galaxy far far away
Other issue is reinforcing your car to handle 450-500hp. Stock G bodies begin to twist apart around 350-400 hp in mint condition. Not to mention brake upgrades to stop that much power.
A Vortec SBC can easily reach 400-450 hp in n/a form.
DRIVEN
8,079
14,556
*CENSORED*
Agreed. A 380-400hp Vortec would be a lot of reliable fun in a driver and leave plenty of budget for exhaust, brakes, rearend, and transmission upgrades. Plus, it's a bolt-in.
SG31
Los Angeles, CA
Thank you all for the replies. My budget for reinforcing the car has somewhat been calculated. It is definitely a concern on upgrading the entire car to make it handle such power. I will say that I do like the idea of the Vortec sbc due to it being much more cost effective and the idea of just pulling an ls3/ crate engine. I guess it is back to the money calculations and searching up offerup/ebay to reassess how much money I can put in the car with the 1.5x rule. Again, thank you all for the help, it is greatly appreciated, especially for someone new like me.
Edit: And LA traffic for me isn't as bad as you guys make it seem :ROFLMAO:. I go out in the day and work a graveyard shift, not sure if that's a thing to brag about though :doh:.
SG31
Los Angeles, CA
* Pistons: Eutectic
* Exhaust manifolds
* Air filter
* Accelerator pedal
Your post gave me inspiration and I found this https://www.jegs.com/i/Chevrolet-Performance/809/19370415/10002/-1 so if I ever do decide to break the budget, and want to go the legal route :blam:, this may not be "too" bad of an option, besides the price...
lilbowtie
3,460
3,965
Canton Mi
As pontiacgp asked why do you want 500 HP. If it's just because I'm alright with that but is there a specific need.
