Run your '72 as is, save up for machine work for the '76.
Building an engine isn't a special skill only people at machine shops can do. Short of actual metal removal, you can do everything else at home. I have a printout from when I had my '76 "Blue Motor" bored without the cam bearings installed, was $140 to bore, $60 to clean, $12 for "shop supplies" (sandwiches?), and 6% Iowa sales tax. $224.72 on April 24th, 2015. Everything else you can do at home. I built both my engines with a 239 piece craftsman tool set with about 20 pieces missing, and a torque wrench. I can do it, you can do it. My local shop charged $45 to install cam bearings, unless you can get ahold of a tool. then it's free. I paid $400 for a three angle valve job, replace any worn guides, two new valves (two were pitted and had lil knurls on them), and removal of 10 broken bolts.
The ONLY "machine work" I paid for on my '70 SP engine, was to clean the block and install cam bearings. I did literally everything else.
People gotta realize, SBB aren't like any other engines, or even like it's big brother the 455 or little brother the 231. There are no "good heads" or rods or intakes or manifolds or anything. No swap meet finds, no hidden speed parts, nothing. No one even makes oil pans for christ's sake. Two of the big 3 when it comes to Buick speed parts have been out of buisiness for over a decade (Kenne Bell and Poston), and TA is the only player left in the game. I'd avoid the ATK/reman engines. They list two, 68-71 and 72-80. Their 72-80 I can tell you right now will be well under 8:1 compression and gutless. The 68-71 scares me, because as some of you know the 68-69 oil through the rocker shafts, and the 70 and newer do not. I'm sure you could call them and specifically ask for a '70 coded engine, but it still will probably have low compression.Plus, I just don't trust reman engines. I'd take it apart and take a look, measure the clearances, probably remove all the casting flash they left in the lifter valley, and then it would need cleaned again. I'd buy a chevy or olds from them, but not a Buick. And they're expensive for what they are. I have just under 2k invested in my running engine.
