Yeah I totally get he has a business and has to make money by selling things. But I also didn't like how he was kinda pushing me into doing so much work on a running engine. I kept trying to reiterate to him "this engine runs as is" and "this is a budget build" and "this is a cruise night car, not a race car", and he still was insistent that the block be magged and shot peened, all the rods checked and reconditioned if necessary, the crank checked and polished at a minimum, and custom ground if he felt necessary. A few things he said just really made me feel like I was being fed a line of bullshit-
"If you are gonna change get the pistons you gotta balance the rotating assembly",
"If you don't bore it, you'll never have perfectly round cylinders",
"If you change the main bearings, even if the bearing clearance is in spec, you need to have to crank custom ground to match the new bearings"
"You have to degree the cam, even if it's not a super high performance engine"
"You can't use just any timing chain, you have to use (brand name) chains that run $200 or they will stretch within the first few hundred miles and the cam will be off"
Now I know just enough about machine work to be dangerous, auto body is my arena, but I know some of that was bullshit. There were a few other things I just didn't like. I think I said before, this shop has a decent reputation, but I've only used them a few times for brake rotors and they did a flywheel for me. I'm gonna check out this other shop tomorrow and tell them what I want done. I'll report back.
