engine problems, again.
67rstbkt said:
David Williamson said:
I actually didn't.
Should I get a gasket now?
Thank you so much, Cause it will not let me download anything and its starting to get annoying, haha.
uh.....yes you should have a gasket there :idea:
Wait I am terribly sorry, It came with the gasket when I bought the spacer.
What was I thinking, Yes it did come with one.
I am sorry for that.
I actually didn't.
So you have two gaskets there, correct? One below the spacer and one on top of the spacer?
CHRIS.O said:
One thing I gotta ask here is, did you use a gasket between the carb and spacer, not the spacer and intake but carb and spacer? I ask because I can't really see one in the picture but it is later and I'm so tired I can barely see straight. As far as the choke I dunno man, that is weird. You have 12 volts going to it so maybe it is an adjustment issue. I will see if I can download the manual and send the text to you in a pm.
that was a nice catch on the missing gasket...
I know right.
I guess I was out of my mind for a second.
But then I remembered that it came with a gasket to go between the carb and spacer and I had a gasket that fit from the spacer to the intake.
But they're all there.
i think i see both gaskets, but that would explain a vacuum leak if there not. Have you downloaded the manual yet? you can get it from there website for free. I think you should try and get the idle mixture screws back to the factory position and go from there, there suppose to be at the same position and from the pics you posted it looks like the right one is almost all the way down (lean) and the left one is out more (richer). Then if it dies on you when you put it in drive turn the idle up some.
I messed with my idle screw and made it run without holding the gas.
But its still running very sluggish and not wanting to go into gear, if I put it in gear then it will die out.
I was also messing with the idle mixture screws and it made it even out, It would run good hen it would begin to run sluggish again.
Yeah that's what i though was weird when I saw them it was out more than the other.
So I turned them all the way in and unscrewed 1 1/2 turns out.
I watched the video on Edelbrock.com But the computer wont allow the download so I have to see if Chris.O can give it to me through PM and watch it there or download it that way.
I was wondering if that's how many turns from the all the way down position 1 1/2 turns?
