jmt455 said:I have to buy the pressure gauge right?
Either buy, borrow or rent one. For the low pressure system, the combination fuel pressure/vacuum gage often comes in handy and they are not very expensive.
Also nothing was done to them other than lashing them, That was it.
I haven't confirmed it but I followed the steps of how to lash them and everything, So i assume they were set properly.
But I haven't had confirmation on them by someone who is a licensed Mechanic, If that's what you mean.
No, I only wondered if you were certain that it was done correctly. Miss-adjusted valves could cause this...
No backfires, But there is a noise coming from the exhaust not a pop or bang, but its a slight plopping noise, I hope you get what I mean.
Yes, I know exactly what you mean. My 305 sounded like that and I could not keep it running. It would stall as soon as I tried to put it in gear and tried to move the vehicle under its own power. I asked about the backfire because that could have been the event that caused the timing chain to jump a tooth or two. This sounds like your timing chain has slipped or, possibly, the distributor has been installed incorrectly (off by one tooth)
Do you have a timing light? I'd be checking that next...
I will go ask autozone tomorrow to borrow one or buy.
Yeah I assume I did them right, from whatever the video told me I followed.
I could have done it wrong but I don't think I did.
Yeah as soon as it goes into gear it will die as soon as it hits any gear.
How can I check with a testlight is its slipped?
