Factory 4 speed owners-looking for a measurement
I'm a conversion 4 speed with a Comp+, but since I don't have a body on the frame I checked to see what the distance is. I got 13-7/16" at the top shifter to plate bolt, 13-1/2" at the base of the stick itself. Everything was from where the mount ear meets the bellhousing.
I got the same measurements as well using a stock ITM shifter in neutral.
there is a youtube video of a gbody tko install. in that video they had to make some major tunnel mods to get it to fit on top of the shifter position issue
The Mustang T5 is 19.51 inches. The standard rear shifter on a Tremec 3550/TKO is the same distrance as the Tremec was originally intended to be an exact bolt in replacement for the Ford T5.
The S10 T5 is 11.74 inches. I found a site that shows the F body T5 (83-92 version) is 9.25 inches further to the rear bringing that measurement to 20.99 inches so the F body version is not much further back than the Mustang T5/Tremec 3550 TKO
Looks like a good option for the future, would just have to fugure out a set up tp make the stick come up like the 3 & 4 speeds.
Do what GM did on the 83-92 F bodies and tilt the transmission. They did this as the 82 F bodies used 4 speeds (Saginaw and Super T10's) with the left offset shifters.
in this pic the orig saginaw shifter position is plated off the sec hole is from super t-10 with hurst shifter that measured 18 1/2 inches from bell housing to trans mounting surface exactly where the speed sensor connector is in the pic
I knew the '82 F-bodies used the for 4 speeds (Saginaws in them used a similar tail housings as ones in H-bodies) but never put any real thought in why the T5 was angled. That does add an idea on making a TKO look "factory".
