Got started on my 350 engine. I done some trading a couple years ago and ended up with it. It was in a late 70s Chevy truck. It was running but mileage unknown. I tore it down to find it all standard and a 2 bolt main. Crank looks pretty good and not much of a ridge so I'm just going to put in new bearings and rings, double roller chain, Summit cam and lifter kit, and a new stock pressure Melling oil pump. I have a set of heads from an 88 Chevy truck that had low miles from being rebuilt. I'm going to lap them and put on new seals. I bought a Weiand Street Warrior intake to fit these centerbolt heads. I also bought a set of Proform aluminum valve covers. I have a 600 Holley carb that I had on a 57 Chevy last year. It is new but since its been sitting, I'm going to take the bowls off and clean them up. I'm on a budget so I'm doing everything myself. I installed a friends MSD distributor last summer and he gave me his Accel HEI that was barely 4 months old. So between used and new parts I had bought for a past project that I just sold, I got some good entry level speed parts. I got the freeze plugs out of the block and three stone honed the cylinder walls. I followed that up with a ball bead hone. I also lightly honed the lifter bores. Gave it a good degreasing and washing followed up by a blow job
I got the old rings off the pistons and retorqued the caps on. I used a 180 grit barrel sanding roll and lightly worked the rods making sure they were not egg shaped. Basically redneck rod resizing. Got to go get some plastigage and 800 grit sandpaper so I can cut it in strips to polish my crank journals. I've built ALOT of small block Chevys but this is the first one I've not taken to a machine shop.
