shotgun said:Huh? You have me totally lost!
If it's pulling to the left, install an adjustable airbag between the strut and frame on the left side.
shotgun said:We will start with this line.
Gbodys don't have struts.
Are you trying to say put a airbag in RIGHT REAR COIL SPRING?
If that's what you are trying to say, yes, that's a old trick.
I have one in my car.
What's the tie in with steering?
JESSE said:custom442.....what i meant by pulling the left tire was off the ground 😀 the car is launching as straight as it ever had...my car used to go side ways on the street and now it's perfectely straight 😀 did you check out the vids? tell me what you think......jesse
So, you compensate with an anti-roll bar.
pontiacgp said:or would a heavier spring on the rear corner that needs it work?...and it's easy and quick enough to change rear springs for street use..
