custom442 said:pontiacgp said:or would a heavier spring on the rear corner that needs it work?...and it's easy and quick enough to change rear springs for street use..
This is why I get it messed up. Because this could work for a drag car. But if you already have a spring around 700lbs/inch, and you're trying to turn the corner, a stiffer spring will cause understeer. I guess this could work for a drag car if it's not being driven on the street. The alternative would be an airbag so it could be adjusted for drag/street driving. I'll have some good info on this after I talk to guys at work tomorrow.
it's a 10 minute job to switch out the rear springs....
