85montemj said:Why would you buy a mini spool just for it to blow up? Whats the point of intentionally wasting money like that? If you're planing on it blowing up weld the damn thing. If you want to do an 8.5" then just wait til you have the money, or get it now if you have it. Or, go with pat's idea. Or, you could even just wait for a posi 7.5" from 85 or 86+ monte SS. It'll handle your 350. I wouldn't make a quick decision just because you want to spin both tires now.
bjohn07 said:damn for 2400 i would have just built my own. with better parts and still would have been cheaper. and posi trac, lsd, locker are all the same. just different names due to manufactures and the patents they used. they all do the same. give power to both wheels under a load yet let one wheel spin a different speed for drivability and wear issues. if ur really interested in a posi check out ebay. i found a posi with 3.42 gears for less than 300. it is used of course but still better than paying 500 for a new carrier. i was gonna get it but im just gonna go check out some j/y
yes really lsd used clutch packs and gears. call any gear shop and ask em. u should know what ur talkin about before speakin. and yes high torque engine destroy clutch packs. thats why they make spools for racing. and call eaton and tell them u need a helical gear type lsd and they will sell u a true trac. which in your words is a true posi. like i said same thing.1983ss454 said:bjohn07 said:damn for 2400 i would have just built my own. with better parts and still would have been cheaper. and posi trac, lsd, locker are all the same. just different names due to manufactures and the patents they used. they all do the same. give power to both wheels under a load yet let one wheel spin a different speed for drivability and wear issues. if ur really interested in a posi check out ebay. i found a posi with 3.42 gears for less than 300. it is used of course but still better than paying 500 for a new carrier. i was gonna get it but im just gonna go check out some j/y
Really? Limited slip used clutch packs, true posi uses gears. Doesn't sound like different names to me, you should really know what your talking about before speaking. High torque engines destroy clutch pack rears, especially during racing
yes really lsd used clutch packs and gears. call any gear shop and ask em. u should know what ur talkin about before speakin. and yes high torque engine destroy clutch packs. thats why they make spools for racing. and call eaton and tell them u need a helical gear type lsd and they will sell u a true trac. which in your words is a true posi. like i said same thing.1983ss454 said:Really? Limited slip used clutch packs, true posi uses gears. Doesn't sound like different names to me, you should really know what your talking about before speaking. High torque engines destroy clutch pack rears, especially during racing
